383 hatch
- Jun 14, 2005
- 3,922
- 67
- 48
- Age
- 41
- Location
- Cowes, Phillip Island
- VG Ute 5.0,Torana hatch 383,WB Ute 5.0,VR stato5.0
OK, so more progress today. I stripped the drivers door back to bare metal. I thought i'd take some pics along the way and show a sort of step by step guide to how i strip the paint off a large panel.
So, here it is.
The first thing i do when stripping paint off is to give the whole panel a quick run over with a 36 grit disc on the sander. I do this to key the paint and give the paint stripper something to bite in to. If you don't do this the paint stripper tends to sit on top and just take the clearcoat off first (especially with 2 pack paint as the clear is very hard and durable). It just speeds up the paint stripper process.
Then just pour paint stripper on the panel and spread it out with a large paint brush. Don't be stingy with the paint stripper, put a nice, generous coat over the entire panel. If i was doing a doors closed respray i would normally tape off the edges to prevent paint stripper from getting in the door jambs, but given this is getting an in and out respray it doesn't really matter.
Paint stripper on.
Then just leave the stripper on for a while and let it do it's thing.
Once the paint has stopped bubbling up, scrape the paint off with a scraper. Be careful here not to gouge the panel with the scraper, just let the scraper do the work.
After the paint is scraped off. As you can see there is still paint on the panel that hasn't come off, so it'll need another go.
So, same again. Stripper on.
Then scrape it off again. This time all the paint came off. All in bare metal. Now the only thing paint stripper won't take off is body filler, so just leave that there for the time being.
Then wipe it over with gun wash on a rag to get all the paint stripper residue off.
Now, get one of these things on an angle grinder and run over the whole panel with it to make sure all the paint is off. Also, if there is some places you didn't paint strip (such as window frames, around the door handle etc.) this will make light work of it.
These stripper discs are the ****, if you've never used one i highly recommend them.
All done.
Then i stripped all the paint off the inside with a combination of stripper disc, various wire wheels on the drill and sand paper.
All finished. Ready for (epoxy) primer. New bare metal looks so nice doesn't it?
So, with that done, i flipped up a few dents and epoxy primed the door. I also put some epoxy on the L/H guard that i finished during the week, the hatch shut and the window frame that i repaired last weekend.
All in epoxy.
That's it for now.
So, here it is.
Paint stripper on.
All done.
All in epoxy.
That's it for now.
