[Ecotec] No Oil pressure after oil cooler
Draimond
VS V6 Executive
96 VS sedan, auto
Ecotec V6 stock engine.
BBG oil pressure & distro block.
Aeroflow remote filter with thermostat.
Maxpeedingrods oil cooler.
Aeroflow hoses and fittings.
15w50
Installed the listed parts, filled oil at engine, filter and oil cooler. No oil pressure.
Cranked for 20 seconds twice with ignition and e.f.i relay disconnected.
Any thoughts on this?
Immortality
Staff member
Sth Auck, NZ
Did you make sure the oil pressure bypass spring and plunger were fitted when you put the new plate on?
Draimond
VS V6 Executive
Yes, spring in first, then plunger on top, with a little oil, checked that it can move back and forth.
BBG pressure adjustment screw is protruding about 5mm against the plunger
Immortality
Staff member
Sth Auck, NZ
Wind it out 5mm (so it is flush as per the OEM setup ) and see what happens.
Draimond
VS V6 Executive
Ok, give me 30 to pull everything off.
The oil pressure sender sits above the screw.
Immortality
Staff member
Sth Auck, NZ
I like the concept, he's definitely "borrowed" the idea from Intense performance in the US and added to it.
The only other thing I can think off is that you have the oil lines reversed somewhere.
Does his block have the OEM pressure bypass built in?
Draimond
VS V6 Executive
No pressure bypass.
My nerves are pretty shot so I'm really not certain I've got the lines around the right way but I've spent half a day staring at it and checking everything and I'm fairly certain I've got it the right way
Draimond
VS V6 Executive
Everything is too close together. Cant get the pressure screw out because of the pressure sensor.
Can't get the block off because of the pressure sensor. Can't get the pressure sensor off because of its self and the pressure screw.
