RX25SE
Real cars are steel cars.
- Jan 20, 2009
- 1,260
- 10
- 38
- Location
- Melbourne
- MY07 Liberty 30R Spec B 6sp wagon
I just realized i had another screencap from EFI live, showing coolant temp sensor voltage along with the corresponding coolant temp.
Also, would an issue with the fuel pressure regulator, or leaking injectors be able to be identified with a fuel pressure test? Or is there a DIY method I can do at home?
Pressure reg can be tested with a pressure gauge connected. Disconnect the vacuum supply and fuel pressure should also rise.
Leaking injectors may cause rough running on initial start up along with a puff of black smoke but will settle to a normal idle quickly.
First test is a Delco suggested. Check vac line for fuel.
Paper towel idea also sounds good but Ive never tried it.
