P0300-00 fault code
Zocky
Caprice WN 6.0
Hi Guys
I have caprice WN 2015 6.0 which has done 80k and I need your assistance engine is running rough and misfires I did diagnostic on the engine and it come up with P0300-00 I changed ignition coils, spark plugs and ignition leads and car is still running rough but what's confusing some times it runs fine and suddenly it starts running rough. Any ideas??
Redline 2017
Goulburn
2017 VF 2 SSV REDLINE
Could be injectors? Not much left besides MAF sensor after all the work you've done, maybe you have copped a bad load of fuel and now have some cranky injectors
BlackVXGTS
Melbourne, SE
The attached from the Holden VF Service Manual may (or may not) help you:
  • DTC P0300.pdf
Kandhol
34
Wn caprice v
Hi Guys
Hi mate i m having a same issues with my wn 2015 6.0 and i changed pretty much everything coils pack, spark plugs, leads, injectors. Plz let me know if you found the solution much appreciate. Thanks
BlackVXGTS
Melbourne, SE
The OP is just another one of those people who post for the first time, get some advice, and are never heard from again. Good luck in getting a reply.
Zocky
Caprice WN 6.0
Hi mate issues with my caprice were injectors changed them and now it's running fine.
Kandhol
34
Wn caprice v
Thats mate i'll look into the injectors i changed. Thanks for reply
