Power steering pump bleed
agentc85
Auckland
VS SS
Quick question for the guru's. I've just replaced my power steering pump and water pump in my vs ss and about to bleed both. Can I bleed power steering without the lil hand vacuum pump? Or will I root it putting it in full lock? Alternatively I was gonna take the belt off it while I do the cooling system. Any help appreciated
Pollushon
Boost gives me a bar....
VY SS
You need only jack the front up, take the weight off the wheels then fill and start the car. Keep topping while it runs. When it seems full turn the wheels near lock to lock and top up again.
If you have a spare set of hands they can turn the steering wheel while you fill. You just want to run it until all the bubbling and foaming stops and you're golden.
greenacc
Searching for the billion
VE Berlina
Yeah, what pollushon said, just keep topping up the reservoir while it's runnin and it will bleed itself.
agentc85
Auckland
VS SS
Solid! \m/ that's exactly how I do the cooling system too, haha
BlackVXGTS
Melbourne, SE
From the Holden VS Service Manual:
Mon-aro
Australia
Monaro CV8Z, VF Wagon, VF ute, VE S1, S2
Hi guys i just replaced my P steering pump in ve sv6, and i tried to bleed it but no go? i rotate to lock the wheel right to left like 100 times and nothing seems to be changing? the steering wheel still stiff as! and the fluid not moving also.
greenacc
VE Berlina
Was that with the engine running or not running?
BlackVXGTS
Melbourne, SE
Not sure why you are posting this in the VR/VS Forum instead of the VE Forum, but here is the procedure for the VE V6:
