Pulley noise v6
Bigartie11
61
NSW
VZ Ute 3.6
Which engine pulley usually goes on a 3.8 v6.Theres a dry sounding whistle coming from that area
DTM87
Abu Dhabi, United Arab Emirates
2004 Chevrolet Lumina S V6 (VY Commodore)
Could be either the tensioner pulley (below alternator) or the grooved idler pulley (below the coil packs) that tend to get squeaky
Greasy Hands
Enthusiast
Wait Awhile
YV II Acclaim, non daily.
on mine it was easy, i removed the belt and spun them by hand. The plastic ribbed one was crunchy to turn - i replaced them all anyway including the belt.
The ribbed one is available in metal in the aftermarket too.
Bigartie11
61
NSW
VZ Ute 3.6
I sprayed them,however there was no silence so I will take the belt off.How long do you think I can drive it for.Its not squealing YET.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Cause it won't squeal with the belt off because the pulleys are not turning, but you will stuff the engine because the water pump is not turning, put the belt back on and read the advice from the posts above.
Loki
Bundaberg
Supercharged VY
mine did the same thing and it was the drive belt .. replaced it ... noise went away
Bigartie11
61
NSW
VZ Ute 3.6
I took the pulleys off and popped the seals,all bearings had no play in them and were greased,with my un trained ear,i`m thinking power steering pump.
0081
VY s m5 supercharged
Get something like a long screwdiver and place it on the pulley bolt and then put your ear to the handle of the screwdriver whilt the motor is running you wll quickly find the pulley thats the cause.
Cmy200
34
Cooroy
Vy storm
Belts stuffed new ones like 40 bucks or one of your pulley bearings is cactus
