I'm not a metallurgist but i thought the whole idea of forging was to force the metal's crystalline structures into alignment which is what makes the end piece much lighter and stronger.
And here's where it gets all murky as there are cold forging techniques where colder (heated to low temp) chunks of metal are quickly squashed by huge weighty presses that slam down on the part to force the metal to flow in the desired way to make the part light and strong. Then there is hot forging which seems to heat the metal above its crystalline structure (thus can't be "forged") where it's squeezed in dies to make the part but it's not as strong as cold forged techniques. There's also a bunch of other die forging techniques that If i understand correctly sit between these two types...
Seems over the years the "forged" name has been progressively weakened to encompass cheaper manufacturing methods using varied techniques. But AIUI, spinning has never been classified as forging so not sure wny it became such? Heck wheel hub caps used to be spun and nobody ever called them "forged"..
So is calling rims made by squeeze casting the centres and then spinning the barrels "forged" seems a complete misrepresentation of their construction technique? I'd think so considering the centre is just heat treated cast construction as the end product is simply not as strong as cold forged wheels (and does anyone do that any more?)...
It's really bordering on false advertising or false product representation as in my view spun /= forged so you don't get what you expected... a really light and strong forged rim...
It would be interesting to note the weights of same size rim that are cast, squeeze cast and spun, hot forged and cold forged to compare against but the wheels we buy don't have their manufacturing technique honestly represented and there's no way we'd know their actuall strength differences, so probably a moot point
May be carbon revolution wheels are the go as they are locally made down under
but for the cost
