mtd
- Sep 22, 2010
- 237
- 199
- 43
- Location
- melbourne,VIC
- VE S1 Calais V V8
Hi all, having a difficult time trying to remove LH side of HVAC to get to the recirc door. Can't seem to move the bugger and feels like something is keeping it in place.
Generally followed steps in this post:
VE Commodore 2009 Single zone HVAC problems
What I've done (see also pics):
Removed cowling (plenum)
Removed glovebox and associated
Removed inside lower ducting
Removed HVAC controller & associated plugs.
Removed 10mm bolt under TX valve on firewall (PIC 1).
Removed 10mm bolt to blower housing under plenum (cowling) near recirc door (cabin filter box) (PIC 2).
Removed lower wiring loom clips to blower motor.
Removed bolt (on bracket) behind wiring loom on left side (have a pic, can't find it!).
Removed blower motor/fan.
Removed screws on housing right side including bugger of a screw that is vertical (see pic 4).
The assembly is only slightly moving and feels like something is securing it. Had a bloody good look and can find nothing.
PIC 1: Didn't remove TX-valve 13mm bolt (directly above arrow) as don't want to regas and I'm informed does not need to be removed.
Just removed the 10mm bolt (at arrow point).
PIC 2: 10mm bolt at firewall (RHS - that's the recirc door to the left).
PIC3: Inside version of above.
PIC4: PITA screw at arrow (hard to make out). When I get this done I'll post pics of how I got this bugger out.
See pic #3 - The bolt that has been removed from the firewall also seems to go into some type of internal clip (in addition to the firewall). I suspect the clip might be holding the assembly in, but as I can't get to it I've no clue what's happening here. Is there a plate on the back of the assembly that comes out with it?
I have jiggled the glove box bracket (LHS) as the assembly bolts into it here - but does not seem to be holding it.
Any thoughts/ideas appreciated.
