mtd
- Sep 22, 2010
- 237
- 199
- 43
- Location
- melbourne,VIC
- VE S1 Calais V V8
OK, so no joy, eff it...
I'm looking for inspiration - 'cause you bunch are an inspiring lot.
Have wiggled so much I feel like a member of the team. It does seem tight up near the AC pipes but looks it'd clear that area. The insulation around pipes drove me bonkers trying to see anything so I ripped it out (i'll replace on refit).
Got some pics:
Clip near TXV (bracket) on
TXV (bracket) off! Managed to wrangle it around & get it off without breaking it.
This is where the casing right meets the evap. You can see it's loose. This seems OK.
This is the bottom of the casing right. The top does not appear to have this white sticky foam (or seal?) - bottom does. This plastic can be lifted a little, but definite pressure there keeping it on the evap casing. The blue tape ('2') you can see is just me reminding myself there are 4 screws on this casing. From the point you can see the white seal(?) start, this goes all around the bottom. Common? I only ask as the upper has none of this.
All/any ideas (preferably constructive...) welcome and appreciated.
Got some pics:
