Spark plugs changed now running rich
Taniwha
45
2007 VE SS Commodore V8 6L Automatic
HELP!!
I've just replaced all spark plugs in my 09 VE Commodore Wagon to NGK Iridium (recommended) now it's running sluggish and running rich.....any advice would be great
uglyoldfatbastard
2010 SV6, 2010 International, 1996 VS Exec
Check your work.
The last thing you worked on is probably the cause so since you replaced the plugs pull them out and make sure they are all fitted correctly and everything else you touched is back where it was when you started.
Get these kind of questions all the time on bike forums such as just changed bars and now fuse is blowing where should I start looking?
Obvious to some that they should start looking at what they last touched but not obvious to them for whatever reason.
_R_J_K_
Zenki S14
Why do you say it's running rich?
uglyoldfatbastard
I am going to guess because a plug is not firing correctly and that is why it is sluggish as well and probably thrown a code to boot.
But just a guess mind you.
Taniwha
45
Exactly. Sluggish. With a code. No engine light showing
ephect
Donating Member
VS Acclaim V6
Check your vac lines are all plugged in and none of the connections are loose or broken
Martbar
67
New Zealand S.I. Otago.
2016 VF Series 2 SSV Redline.
Mate as above, and if the code was logged after you changed the O2 sensor it could be a problem with the sensor.
Capsule
Brisbane, QLD
MY09 VE Omega
No engine light means the code is about a condition that is not present anymore (were the codes cleared after the sensor was changed?) but you could have a new condition developing. Put your scanner in data grid mode and look for any misfires / check your fuel trims. Could be an issue between the plugs and the ignition coils. Make sure the coils are properly pushed onto the plugs.
