Squeaky Suspension
ProbablyRaging
Drop Bass, Not Bombs.
FUNK, Uptown
Vroom Vroom Car
Just wondering if there is an easy way to fix squeaky suspension? My front right suspension has been driving me nuts lately, every bump in the road makes it squeak like an old bus, quite embarrassing really.
I can't actually tell where abouts the squeaking is coming from within the suspension, but is there anyway I can atleast quiten it down until I can find a permanent fix for it? Maybe some WD40 or something? Lol
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Confucius say "If it squeak, oil it" or use silicone spray preferably, of course that is providing it is only sway bar rubbers etc., and not major component (wheel bearings, shocks etc ) failure, then you need to fix it.
WD40 is more a drying type spray.
Most cars-trucks squeak, grind, bang, after rain.
ProbablyRaging
FUNK, Uptown
Vroom Vroom Car
I'm not sure what the part is called but it seems to me like its coming from a bar that runs under the engine, just behind the radiator and connects to both sides of the suspension.
Any ideas?
ephect
Donating Member
VS Acclaim V6
swaybar link try spraying/oil/grease the 2 rubbers then take it for a strap, if it squeeks, its not it, continue trying other rubber mounts til it no longer squeeks
ProbablyRaging
FUNK, Uptown
Vroom Vroom Car
Alright, gave that a go, went for a drive, its a little better but still really squeaky.
Is there an easy way of undoing the sway bar and getting some grease into the rubbers rather then just applying to the outside?
muzza
51
gladstone
vx berlina
are the bushes red ? cause if u have nolathane bushes like me instead of rubber they do squeak a little
ProbablyRaging
FUNK, Uptown
Vroom Vroom Car
I believe so yes, if you are talking about the bushed that are bolted to the frame facing towards the front of the car? I'm not great with cars, I know abit but deffinately not suspension wise.
Where can I pick up some nolathane or white line link pins and bushes? And how hard to replace them?
