LS1 James
Donates His Member
- Jul 29, 2008
- 566
- 3
- 0
- Age
- 39
- Location
- Andrews Farm, SA
- VT II GEN3 V8 Wagz
I "Borrowed" this post from another site:
the converstion is an all bolt in job basicly. best thing to do is buy a donar car from the auctions like i did. and use the vn k frame. Suspention and breaks too if you want. And if ur useing a th700 box use the standard trans crossmember with a th400 trans mount. But if u sue t5 5 speed ya have to mod the crossmember a little. not much pretty easy if you can weld and again use the th400 trans mount. I have been told i can use my standard vk tailshaft but it wears out centre bearings a lttle more. and also have been told ya can use vn front and vk rear. or just get the vn one shortened should only cost about $150-$200 to shorten.As for radiator you can use the vn one but have to cut a little at the bottom of the rad suport or ya can use a vc vb vh vk vl v8.As for wiring just plug and play basicly.
- He states that if your using the Th700 box (which i will be) that i can use the standard Auto crossmember (VH or VP???) and put the Th400 Trans Mount on it.
Can someone throw some pics up of the crossmember with the trans mount on it so i can see exactly what he means? Is the th400 trans mount a direct fit to the (VH or VP?) Crossmember?
