Scatman696
- Feb 17, 2024
- 86
- 23
- 8
- Age
- 47
- Location
- Currans Hill NSW
- Vk berlina
Yes it does have a return fitting (tho not connected by the looks of it)Cant really tell 100% but want to say vn due to bolt in sender & oval eclectrical plug.
Does it have return line fitting on driver's side of tank?
Top of tank where filler neck goes can you see rubber joiner for filler to tank or is it joined to tank?
Should be able to jack car up high on jackstands...take bottom bolt out of sender unit fuel should leak out to drain decent amount out or if easier trigger fuel pump to run from relay or hotire it.
Yeah sweet - plan to do the pull out Monday. Rare spares have a sender unit for a VN in stock on hold for me if needed
