Conceive This
- Apr 13, 2008
- 14
- 0
- 0
- VS SEDAN
pressures
I Work for beaurepaires
and i have done plenty of Tyre technology coarses and this is what ive found.
NOTE: First off remember the tyre placcard on the vehicle is factory fitted
this is the comfort level prescribed by the vehicle manufacturer and is not tyre rated
15'' and 16'' pasanger tyres = 30-32psi
17'' Proformance tyres= 32-35psi
18'', 19'' and 20'' Proformance tyres= 34-36psi
work utes and vans pressure set to 40psi
Now of coarse this is only a guide if you feel its a bit sloppy
you are able to increase these measurements
NOTE: NEVER EXCEED MAX TYRE PRESSURE (located on the side of the tyre)
this is usualy but 50psi
Remember more pressure gives you greater steering response tho can stress the tyres integrity, also there is less give if you hit a pot hole this could cause tyre sepperation (sidewall bubbles) or damage your rims..
NOTE: if you are travaling log distances ie. interstate all measurements should be increased by 4psi this also aplies to fully laden vehicles.
With 4WD
all tyre pressures should be set to 40psi depending on your comfort
Now all these measurments should give you maximum life and proformance
from your tyres...
SAFE MOTORING...
With 4WD
from your tyres...
SAFE MOTORING...
