VE Commodore Aircon problems and more
Discussion in 'VE Holden Commodore (2006 - 2013)' started by houdini_007, Feb 8, 2010.
  1. houdini_007
    houdini_007 New Member
    VE (V-Series) Omega with alloy wheels & rear spoil
    Hi everyone,
    I apologise in advance if this has been discussed before….
    I have a few issues (again) with my car & was wondering if you anybody might have any feedback on the following; (other than I should by a Toyota or Ford() 
    1. Air conditioning – Switches off after approx 2 min on really hot days. Not only the air conditioner, but the actual fan itself.
    2. The air ventilator flaps directing air from your face to down to your feet seem to be stuck / not working. As soon as you start the car, you can hear a clapping noise under the dashboard. There is no air coming out from the rear of the armrest to the back seats.
    3. Clutch / Gear shifting – When exhilarating you can hear & feel a shudder going through the car. This is not a smooth shift like it used to be, but almost a thumping noise when the gears change.
    4. When driving on a smooth & straight road, the Stability Control warning comes on for no reason.
    Thank you.
  2. UFO
    UFO I Believe
    MY10 VE International Sportwagon SIDI 3L
  3. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    what year model is your car, sounds like the issues the very first releases of ve's got, most got fixed with software updates, other things got fixed by replace the hvac unit
  4. houdini_007
  5. houdini_007
    Andy-the-man! We've got a 2006 VE Commodore. Maybe it is one of the first guinea pigs of the assembly line?
  6. andyman
    Orange, NSW
    spot on i take it you bought it second hand and it used to be a fleet car which wasnt serviced at holden?
    what youll have to do, is take it to holden, and first get them to see if its got the latest firmware, see how that goes with problems, if that dosnt succeed id take it back again,
    id also try and push for warrenty on it even if its out, car companies do do it on occasions if its a common fault once cars are past its warrenty, even if you get parts free and pay for labor kind of thing.... but if it was serviced at holden, even more reason to push for warrenty as they should have checked that
  7. houdini_007
    Nope - The car has always been serviced at Holden. It only has 29500km on the clock & serviced at the same dealer to keep the extended warranty alive.
    I will make sure they check it all out - Thank you.
  8. andyman
    Orange, NSW
    well if you send it in for the 30km service id be asking for fixes, its well documented in holden techlines
  9. Azza84
    Azza84 New Member
    Newcastle NSW
    WM Caprice
    holding the demist button in for 10 seconds resets the air con system and usually makes them colder. Hope this helps
  10. houdini_007
    Thank you - I've had it at the dealers yesterday & they said I need to bring it back for two days to replace the heating/cooling unit (HVAC??).
    Aparently there's a control module in there that can't be replaced & they have to replace the unit. Didn't kick up a fuss about it as I'd prefer to get the unit replaced & hopefully get another 3 years out of it. :)
  11. andyman
    Orange, NSW
    they covering it on warrenty for you?
  12. MYVESSV8
    MYVESSV8 Active Member
    Brisbane/GoldCoast
    VE 6LT M6
    aircon issue
    do you do this with engine running or just keys in ignition and turned on etc:hmmm:
  13. vicarious
    vicarious New Member
    SA
    VE2 SV6 SPORTWAGON
    engine running and put it to window demist and hold the recirculate button for 10 second and the light on recirculate will flash
  14. 1957chev
    1957chev New Member
    VZ crewman
    Hello my VZ ute switches over to the screen when I floor it ? then when I back off it comes back to where it is set ? any ideas ? seems like a vac leak but where ?
  15. bennyrocks_79
    bennyrocks_79 New Member
    vs ute
    Yeah mine wasn't blowing at my feet although you could here it move. The duct is actuated by a small motor assy and is a pain in the ass to replace but you can get to it from under the dash if you lie down and reach up. Olny cost $19.00 and a lot of bad words.
  16. sd1201
    sd1201 New Member
    Newcastle
    VE Commodore
    Awesome.... thanks heaps... i was about to put the car in for a service to get this same problem fixed but this quick little trick did the job
  17. michaelp2006
    michaelp2006 New Member
    Queensland
    VT S
    I tried this with mine, now the air con blows hot on demist and wont change position or temperature
  18. MYVESSV8
    Brisbane/GoldCoast
    VE 6LT M6
    sometimes you have to do it couple of times, is yours clacking when ign turned on
