lmoengnr
Donating Member
- Jan 15, 2012
- 6,991
- 46,029
- 113
- Location
- Sunbury Vic.
- MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
You haven't had the windscreen replaced?Any ideas?
I have not in the time I've owned the car.You haven't had the windscreen replaced?
I've greased the hinge pins, though obviously as they're a bolt-in part worst case I could replace one. There is a click on opening the door, but I'd be surprised if that's the source of the noise with the door latched closed. Are you sure this could be the cause? If it is I'll track down a good replacement and go through the procedure to fit it.Re-reading this, I’m still going with worn door hinge pin or worn check strap pin.
When the door is closed any flex goes to two areas. The latch and the door hinge pins. You are confident the striker is good. So a worn hinge pin would be the next weak point.
Also the mirror is worth checking.
You’ve had the door trim off to inspect the door inside? Inspect the door actuator assembly. Ensure it’s torqued to spec.
I've just replaced the front struts and top bushings with KYB & superpro. No improvement.The other thing before going further is absolutely eliminate any possible front right suspension issues. The noise of a worn bush or damaged strut top will refer through the body and appear as a sound somewhere else.
Our front right strut top was buggered and that was a sound similar to your description. Lower control arm bush, sway bar bush all could be interpreted as coming from the A-pillar area.
Which SuperPro strut tops were fitted?I've just replaced the front struts and top bushings with KYB & superpro. No improvement.
I think you may be on the money with the hinges.
Can the hinge pins be replaced without replacing the hinge as a whole? If so might be best to just do it anyway for maintenance purposes.
