mtd
- Sep 22, 2010
- 230
- 185
- 43
- Location
- melbourne,VIC
- VE S1 Calais V V8
Nice clean door - like it! I am, however, a bit disappointed that you didn't wipe the top of that speaker bracket! Look at the dust! Tsk tsk.I bought my VE wagon about 3 months ago shortly after I could hear water sloshing in the doors. i checked the drains and they were completely blocked--About 3l of water came out each rear door and the amount of mud in the doors made me think it had been parked in a swamp. both rear speakers had practically disintegrated so I replaced them all with some 6.5" Kicker CSs i got on sale for $100 a pair at Autobarn
Yes, the VE door design is not the best for water shedding. One of the keys is to keep the drain holes unblocked. Its not sexy work, but it's important. I remember cleaning out my & my dad's HD/HT/HQ/HJ drain holes. It's always been important.
Another thing is that if the top of your plastic is not sealed securely, and your bottom is... well, you have a problem!
I spent the better half of a day completely cleaning out the door inners. It's the build up that will slowly block the drain holes - little-by-little. The dust cover (plastic) and weather seals will only go so far.
OK, you do feel a bit mad cleaning the inner of a door you don't generally see - but I've been seen vacuuming the engine bay below the plenum for leaves that I can't normally reach - that cause all sorts of problems with blockages/water redirections/rust etc. So I guess I'm mad...
See all those holes in the door above the speaker (put there for various access to the window lifters etc)? I also sealed those off with waterproof tape. It's easy to peel the stuff I used off for any later access. I can't see this would cause any air circulation problem with the door cavities below.
