VE SV6 Ute LY7 MAP Sensor
tander977
46
Ballarat VIC
VE SV6
Hi all, can anybody tell me if a 2008 VE SV6 Ute LY7 has a map sensor? Quick Google search shows a map sensor for a LY7, i removed the intake plenum and couldnt find the one pictured anywhere. On the back of the intake plenum is a big round type of sensor with a plug for wiring loom. On my scan tool shows Barrometric Pressure and volts. I purchased the map sensor pictured thinking that would be the right one though no luck locating it.
Fu Manchu
WA.
The MAP sensor is used for barometric air pressure readings as part of the engine management system. It forms part of the data for trimming fuel ratios.
It is located on the back of the intake plenum on LE0 and LY7.
It’s the same sensor, just not being used to measure Manifold Air Pressure.
