leif72
- Jan 16, 2013
- 8
- 0
- 0
- Location
- South Australia
- VE Omega 06
Have recently bought a ve omega 06 with 90,000 on it, and although it drove well, found the check engine light came on after a few weeks, at the same time noticing a slight rattle in the engine. Went through all the scan tool, oil sensor process to get to the bottom of it, only to find out that the timing chain is stretched and that this is a common problem in in late vz`s , early ve`s. have been advised that im better off getting a new engine as the stretched timing chain could have done other damage, the cost is $4000 for an engine with 50,000 on it, which isnt too bad considering i paid $10,000 for the vehicle, so im still around market value, if id paid $14,000 id be out for blood!, apparently they used a thinner timing chain but rectified this in 09. For a timing chain to stretch after 90,000 kms is rediculous.
Btw, the mechanic i used is a trusted friend and in his search for another engine spoke to alot of other mechanics about this issue, he discovered that those particular engines are known for the timing chain stretching at around the 120,000km mark, depending on how its driven i would guess.
