TeknoVFSS
Hi Team,
Long time follower, finally joined up first time poster.
Iv searched all over but can’t seem to find a definitive answer so here i am.
I have a VF SS series 1.
She is sitting way too low from the previous owner who also has the rears cambered which is causing wear on the inside of the rear tyres which I just had to get replaced.
I’m going for BC racing coilovers to raise her up a bit to close to stock height and hopefully fix the camber rub at the rear (not the reason for this post iv had BC coilovers on other cars and like them, iv looked at spring/strut combos but not sure what to get for stock height etc and like adustability from coilovers)
I’m also wanting to add sway bars while I’m at it.
Looking at whiteline kit (fits FE3 suspension)
or
Superpro (does not fit FE3 suspension) I’m not sure which one to go with that will fit the coilovers ? And what else I will need (links etc)
Any info/advice on this setup will be appreciated Thankyou.
Will also do a post up soon showing the full build/info on this 450HP tekno SS soon.
or
