VN Map Lights
Redline16
MY16 VFII SSV Redline Manual
I know when I went to put LED globes in my map lights in my VP, they wouldnt work and I later found out the positive and the negative need to be switched over for it to work, so I didnt bother in the end.
HOONER
27
Kalgoorlie
VE Maloo
All you have to do it pull it out and turn the globe 180 and then it will work. Anyone who has worked or installed LEDs knows that
Sent from my XT925 using Tapatalk
Redline16
Apparently it wont work with these map lights, and besides how can you turn around a BA9S type globe when they are a bayonet style globe?
Im only going by when ive fitted LEDs to my VP Calais and did all of the lights except for these lights due to this problem. It was what I was told by Bright light Auto Parts in Ferntree Gully, Vic.
KrisG
'96 VSII Berlina
This is correct, the map lights are a reverse polarity connection. No matter how you turn the bayonet it wont work because the negative is at the tip of the bayonet and positive on the side. When using standard halogens, this doesn't matter because they can be hooked up any way, however, LED's only work one way and you must get the correct globes. I ended up buying these 2X BA9S 5 SMD Reverse Polarity White 5050 SMD T4W 1895 Bayonet LED Dash Parker | eBay
hakhawk
smooth moderator
Staff member
to help you improve in your "business", heres a link to common globe types
Signalling
they also have a vehicle application guide on their site.
if you want your "business" to succeed, you cant rely on waiting for replies from people on the internet. do the legwork and get it sorted on the day. not everyone is willing to wait.
Redline16
Signalling
I agree with hakhawk, especially when you tell me to turn a bayonet LED globe 180 deg to get it to work....
Jxfwsf
Aus
commodore
What if i turn an edison screw fitting globe 180° will this work? will the glass insulate to well and not allow current flow... or am i turning it the wrong way?
hakhawk
smooth moderator
Staff member
you didnt specify clockwire or counter. remember, it depends where the light came from and if you're above or below the equator, much like the flow of a toilet bowl, everything spins backwards(simpsons taught me a lot)
