VR commodore
losh1971
North Tas
VE Series I SS Ute
This is what it should look like. I tried finding an engine diagram but have run out of time.
losh1971
North Tas
VE Series I SS Ute
Maverick86
VR 3.8
Post a photo of the bay from further away and include the steering pump without the pulley attached and a photo of those steel pipes to see where they go.
OK, that makes sense, those steel pipes were to supply coolant to the LPG converter, without it they freeze up.
You can remove those steel pipes and just refit the standard hoses.
Thank you that makes a lot of sense I only just had the converter removed just before pits
Maverick86
VR 3.8
Maverick86
VR 3.8
Also pull those two short hoses off. Something doesn't look right. with the way that bypass hose doesn't connect to the timing cover.
Sweet as thank you I will pull them off and have a look and post a pic soon
