rlumb
- Apr 17, 2023
- 2
- 0
- 1
- Age
- 28
- Location
- qld
- vr statesman
Hi Guys,
I have a VR statesman with me at the moment that wont select first gear unless its turned off and turned back on again. Bit o a back story, the owner did a tranny filter and oil change on it and damaged something internally. The gearbox was sent off to be rebuilt. When the gearbox came back it was fine for an amount of time i believe then it started having this issue where you can put it in drive, it will take off in first gear but once it goes in to second gear it wont go back to first unless you turn the car off and back on again. ive so far tested the vss which tests within spec, ive tested continuity/resistance between vss and ecm everything normal there, i have had oscilliscope on the vss and wave forms are not that great. ive also tested ac current into the ecm and getting 0.080mV, ive also tested speedo out put from ecm and it measure 8.53v which is out of spec and doesnt change with vehicle speed.
the vehicle does display code 24 for VSS
any help would be muchly appreciated.
