VS 3 instrument cluster short and now no alternator charge?
a.revhed
54
Darwin
VS III Statesman
Hi Everyone,
I've lurked here for years, but only now that I need to post realised I hasn't signed up...
I have a VS series 3 5.0L Stato. All largely stock
I was trying to replace some of the bulbs in the instrument cluster on the weekend. opened the under-dash cover and was trying to get at them through the windows in the steal frame of the dashboard mounting. When I couldn't turn them with my fingers I went for the pliers....and think I touched something I shouldn't have! Now, the warning lights are all off. But Tacho, Speedo, indicator lights and the fake seatbelt warning lamp all still work. Everything seemed fine, but now I get the chime for the handbrake on while moving sounding at intermittent intervals. The battery seems to be slowly going flat, so assume no alternator charge. (It's a new battery)
All other electrical components seem fine. Radio. AC blower, headlights. etc all working. I checked the obvious fuses and all look ok.
Any ideas on a quick fix for the alternator issue? I've sourced a new cluster, but it will take a few weeks to arrive, and can't afford to park the car up that long!
lout
60
Langwarrin Victoria
charge battery each night and dont use heater/demister and try to limit headlight use
ephect
Donating Member
VS Acclaim V6
Pop the cluster out to check traces at the back to set the extent. Could be a simple one
  • Like
Reactions: Lex
a.revhed
54
Darwin
VS III Statesman
yeah, I did think of that....but not sure how the instrument cluster can affect the operation of the Alternator. Seems a bit fragile if something in the warning light system can stop the charging system from working..,.
lout
60
Langwarrin Victoria
if it uses old school bulb in the exciter circuit
then who knows what happened
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
probably does ! (as no BCM control back then)
so
yeah who knows what has happened
Immortality
Staff member
Sth Auck, NZ
Probably blown the loop for the warning light circuit, the alternator excite circuit runs via the dash warning light and with this not functioning the alternator won't charge.
In theory, you could cut the wire at the alternator, wire in a 2w 12 volt light bulb to ground and then it should work.
a.revhed
54
Darwin
VS III Statesman
Could I run a lead from the battery to the alternator sense terminal instead, bypassing the need for splicing in the bulb?
lout
60
Langwarrin Victoria
need to drop the voltage down to around 8 volts
Immortality
Staff member
Sth Auck, NZ
No.
There are 2 wires, the sense wire is for the regulator to monitor battery voltage and adjust output to suit, the excite wire is different and it needs a small electrical load (the light bulb) to pull a small current.
