vs ute ecotec
shagaz
victoria
vs ute ecotec
B5AFB776-C30B-42B0-8AC8-3A1C3C37C882-285-0000012B30CB68AF_zps20f4aeea.mp4
shagaz
victoria
vs ute ecotec
well, after a year an a month of being a good boy not a single infringement, pulled over today in the way to work, defect on the window needs. 4 new tires, wheel alignment, new drivers side seatbelt, an he asked for a RWC as well,
lost my license as well, 4 demerits, $387 fine, doing 107 in an 80 zone,
serves me right though, my fault, lost it for a month,
tires are getting done as we speak, got a seatbelt from pick a part today,
but because he wants a roady. I'm gonna need bump stops, a windscreen, wipers, change my springs, an what ever else they want I guess, so motor. will be coming out over the next few weeks, cause the car will be parked, luckily I have a darling of a girlfriend, Shea driving me an picking me up from work, so was stressed this morning, but yeah, so there will be updates coming, got time to work on it now.
shagaz
victoria
vs ute ecotec
if anyone has the same problem as this,
between the panel an door sill I got rust, I treated it when I first got the car but I want it gone, thinking about cutting about 200mm up, an from the wheel arch to the door, basically remaking the bottom panel an sill as one, without the lip there anymore, would have to do it to both aides but yeah ideas ? will update soon motors coming out this weekend for roady cause water leak is to fast
shagaz
victoria
vs ute ecotec
where's the love ? startin feel like no one gives a crap, haha
if anyone can help me out it would be much appreciated, motor is coming out this weekend, well starting to, is there anyway to properly clean the radiator like new again with our getting someone to do it ?
an while the motor is out I there anything else I should to do it, asked so many people but no one really knows
shagaz
victoria
vs ute ecotec
well, after a pretty long arvo an night, got the motor out yesterday, found the problem an a few others haha,
major problem was the back of the motor that plate that houses the rear main seal, the gasket between that an the block was gone, an also a torn engine mount. today I'm gonna spend all day cleaning it down, clean the sump, the manifold an the bay, ordered a full gasket kit for top an bottom end that will be in Monday so pretty happy, first time iv ever done that an no issues
this I why I was getting a huge water leak at the back if the motor
passenger side
drivers side
intake all clean
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
I'll PM you.
Lucky the rear main housing gasket didn't split from coolant to oil.
Better off buying a new rear main housing.
I'd remove the radiator and chemically clean it. Also foward and reverse flush it and give the fins a good clean.
What brand gasket set did you get?
I'd change majority of the ECU sensors and give the engine a good, clean tidy up.
Clean the injectors of carbon deposits too and check the PCV valve.
shagaz
victoria
vs ute ecotec
I'll PM you.
I took all the injectors out, there closed but they definitely need a clean, what's the best way to do that ?
couldn't tell ya the brand mate but it is gonna set me back about 250 - 300 ? does that sound right I'm new to this haha, oh okay forward an reverse flush as in flush it backwards the way the water pumps an forward ?
an Is the PCV valve the spring thing in the intake manifold ?
K-BAGZ
De Plane! De Plane!
Far North QLD
I usually clean carbon clogged injectors with kerosene and a bronze wire brush. The best way is to get them professionally cleaned in an ultrasonic bath.
I can't remember what my VRS kit cost me, but that sounds alright.
Yeah, water in the inlet of the radiator from the thermostat, and water in the outlet of the radiator to the timing cover pipe. Give the radiator a good flush in both pipe ends.
That's the one.
The Ecotec's are a pretty strong engine if you take care of them properly (Maintenance and pedal work).
shagaz
victoria
vs ute ecotec
That's the one.
How do I check it mate, I pulled it out an cleaned it all up the spring an all that seemed fine, but yeh how do I check it ?
Alright sweet man, radiator is next weekends job,
Yeah they are pretty trustworthy motors haha, I haven't really looked after mine, time to start haha,
With the injectors do you just clean the outlet an inlet with the brush, or ?
Thanks heaps bud
