vs v6 stalling round right corners
jas98
34
maryborough QLD
vs commodore V6 S2 and a BA XR6T
ok so last week had a problem witch turned out to be inside of fuel filter comming apart reatricting fuel flow and possible burning out injectors. any was replaced injectors with some vt ones i had and new filter. Now car stalls when turning right.
weired thing is if it was very low on fuel....like fuel light on.....it wants to stall but does'nt. but i put fuel in yesterday and at just over half a tank as soon as i turn right it stalls straight away so have to carefully pull over and restart.
could fuel pump have burnt out seeing there was excessive presaure building up?
VS 5.0
More lkely the return line in the tank that connects to the swirl pot.
jas98
34
maryborough QLD
hmm ill have to look into it
so it did it again but this time wouldnt restart....untill a minute after. could hear fuel pump priming etc but no start
Immortality
Staff member
Sth Auck, NZ
Check all the vacuum lines on the intake, under the throttle body/purge valve etc.
jeepyrocks
BMW 535D, VR V6 Ute
does it just cut out or does it splutter and then die? Have seen the wiring harness to the DFI module do similar, but this makes the car cut out instantly.
jas98
34
maryborough QLD
did spluttler a little but now just turn right corner hard and it dies and comes to a stop.
i had the wireing problem at dfi a while back and it butnt wireing so replaced wireing loom and coil pack and dfi.
does seem the same symptoms though.
