VSS analog to PWM
DannyboyDS
Just hand me the pliers.
39
VS Berlina
Ok so im converting to manual in my VS, I have a remapped ECU, but of course as eveeryone knows I miss out on the Vehicle Speed Sender, as the standard VS auto ECU uses Pulse Width Modulation (PWM) and the T5 I am using uses an oldschool analog signal, like high or low voltage.
So after considering all of the possibilities, such as.
1. Locate and use the correct ECU (To expensive and ahrd to track down)
2. An off the shelf converter (Could only find them in 8 pulse, I need a 40 pulse)
3. go without (Is problematic
4. changing over to a completly different ECU (Can be expensive and allot of mucking around that can result in everything not working)
So in the end ive decided on this as my project.
The picture below is a little rough and ready but hey, I did my best.
attachment.php
Basically the shaft of the old VSS goes through a bearing (for support) and into a plastic hobby box (Trying to reduce the amount of magnetic metal as not to affect the PWM generator.
the PWM generator has to be placed correclt alignment and distance from the reluctor ring are crucial, I have the figures somewhere, otherwise, back to google I will go :p
finally it also comes down to the gearing, need to get 40 pulses per driveshaft revelution for it to work straight off, otherwise a speedo corrector kit will be needed.
Anyone got any thoughts? any info? anyone allready done it? or is anyone good enough with circuits to make a PWM generator that increases pulses dependant on input voltage?
Better yet anyone seen a 40 pulse PWM generator on the net for sale, they basically replace the old VSS, plug right in, as the cogs turn it creates a PWM signal.
DannyboyDS
39
VS Berlina
I think I found an off the shelf item that does this. With the amount of people doing manual conversions and using the auto ECU, I thought there would have been more interest.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
i think the jaycar speedo corrector may be able to do it or there is another unit that can do it just noone has tested them and proved it works yet :D i can get a link for the one to turn sine wave in to square wave out or vice versa if you need it
DannyboyDS
39
VS Berlina
That would be great thanks Delco, I have scoured the net and have found what I hope is an off the shelf VSS, that will go directly into a T5 without any modifications, and emit a pulse wave for the AUTO ECU, so I might be in luck anyway.
I just don't know why it isn't talked about more, I mean arn't allot of people having conversion issues, or are they just lucky enough to have an ECU that suits?
Chirpstr
A new project attack
VR Berlina M5, VP M5
I thought the auto VS ecu has the manual speed sensor reading in it already? Only the VS ecu though.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
only certian VS auto ecu's have the nessacary internal componants
DannyboyDS
39
VS Berlina
well i've allready bought a VSS, hmm maybe i'll buy both :p
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
just be aware this all could be a waste of money if the ecu is seeing auto speed pulses cause its programmed with specific gear ratios in the tune and it may pack a mental at you due to the manual having different gear ratios
ejukated
VS Calais L67
it will be fine, if the pulse is actually suitable to be read through the auto vss pin. Thats just the same config as a getrag gearbox
