VT-VX Hidden Trip Computer
VT&VX
90
VX Acclaim
but you lose over speed settings & control (you are no longer able to change the speed setting.
I get the overspeed flashing light on the dash. ( I didn't get it before)
I hope I can change the setting to higher speed, because that will be annoying on the highway
VT&VX
90
VX Acclaim
radio pin is in bcm security section
There wasn't anything listed there.
Does anyone know if Tech2 actually scans the electronics of the radio/cd or if it is just displaying a text entry field that may or may not have been updated by Holden. (Meaning if it was never typed in then it will never be found with a tech2)
lout
60
Langwarrin Victoria
it is just a text field filled in by holden, but the section should still be there
i will go check , back in 5 mins
power up->diagnostics->year->model->body control module->body control module ID confirm->ignition confirm->security->security information->confirm anti theft disarm->
brings you to all your security codes, radio, ecu link code and key number
VT&VX
90
VX Acclaim
Then mine wasn't filled in. Or something has been changed
Craig Facey
42
Sanctuary Point
VTII Calais 5.7
Does anyone know what all the codes in P (police) mode and Diagnostic mode mean? If its not working for you then for diagnostic mode hold mode and up button as opposed to mode and down button before inserting key and starting car for Police mode. Some of the codes in P mode look like hex codes and I was wondering wether any of them could be decoded into trouble codes etc (i.e. when you cycle through the options using the mode button and see a string of six numbers and letters in the centrre panel then press up and down buttons to cycle through a list of these mysterious number-letter-strings)?
Also in reference to previous comments about the counter for the number of trouble codes and the stereo pin number I have a "ga" label and a "pg" but no "pn" or "psi" label in the right hand side (third) window. Note that my factory stereo has been removed.
So does anyone have this Gregory's manual that other comments refer to as having instructions in it on what all this stuff means?
P.S. I know mitch01 gave us some info in this article http://www.autospeed.com/cms/article.html?&A=1951 but that was a while ago and thought someone might know more now?
Thanks!
lout
60
Langwarrin Victoria
hey craig please dont use the term police mode
it is engineering or diagnostics mode
as for that article. he should be sued for fraud
like a fool i paid for the access to get a load of "dont know what this is and might be"
here is the real info
Trip computer diagnostic codes
Hold mode and up arrow then turn key to on or start
Release buttons
then
Press Mode = Dash Part Number - e.g. 1731
Press Mode = Mode Switch Voltage - e.g. BV - - - 5.0
Press Mode = Battery Voltage - e.g. V 11.8
Press Mode = Petrol Sender Voltage - e.g. FUEL 02.6
Press Mode = LPG Sender Voltage - e.g. VL 5.0
Press Mode = Remaining Fuel - e.g. 38L
Press Mode = Instantaneous Fuel (Liters per Hour) - e.g. 12.8 L/H
Press Mode = Engine Coolant Temp - e.g. 63 C
Press Mode = Vehicle Speed - e.g. 45 KM/H
Press Mode = Tachometer - e.g. 2380
Press Mode = Park Lamps Switch - e.g. P OFF
Press Mode = Dash Trouble Codes - e.g. t 00 (Press up/down to scroll through any codes, these are not PCM, ABS, etc codes)
Press Mode = Dash Test - All gauges will move, lights will come on and buzzer will sound.
Turn key off will revert to normal dash
Dash trouble codes
Format is t then code number then history then current some have nu which I cant remember but believe was not used
Eg
t00-- is fuel gauge sender open circuit no history and no current faults
t16h- is abs history codes but no current fault
00 Fuel gauge sender unit — open circuit
01 Fuel gauge sender unit — short circuit
02 Fuel gauge sender unit — intermittent
03 Fuel gauge sender unit — open circuit
04 LPG gauge sender unit — open circuit
05 LPG gauge sender unit — short circuit
06 LPG gauge sender unit — intermittent
08 No serial data from ABS
09 No serial data from BCM
10 No serial data from ECC
11 No serial data from PCM
12 No serial data from SDM
13 No instrument poll from BCM
14 No serial communication
15 No Sub-clock
16 ABS or ABS/ETC fault logged
17 BCM fault logged
18 ECC fault logged
19 PCM fault logged
20 SDM fault logged
21 Trip switch short circuit
22 Trip switch button stuck
24 EE checksum error
25 ROM checksum error
26 Internal fault
Craig Facey
42
Sanctuary Point
VTII Calais 5.7
Thanks I will go and try it now.... I did think it seemed eroneous to call it "Police" mode ;)
Craig Facey
42
Sanctuary Point
VTII Calais 5.7
So I got a HC on 19.... Would a Tech2 scan (or Holden service centre of they use anything OEM?) give me any more information about what the power control module fault is?
lout
60
Langwarrin Victoria
HC on 19 means the ecu/pcm is reporting a current fault
bridging 5 and 6 on obd port should tell you what it is
edit sorry craig just realised you have the 5.7L
bridging pins wont work on your car
deejvxss
coffs
vx ss
Looking for some help. I have a vx ss I bought and the key that came with it wasn’t programmed the dash was working before we played around trying to start it not knowing the key wasn’t programmed. Now none of the dash is working not even the trip computer is working or any of the gauges it’s not even displaying the kms. It was all working fine when I bought it, it just wouldn’t start as the key wasn’t programmed. Nothing was wrong with the dash before and need to work out what’s wrong with it as it only has 125,000kms on the clock I’ve checked all fuses and none were blown. Hoping someone might be able to help me
