VU V6 engine mounts
Kayne_L
19
Ulladulla
Vy
Hey guys I’m trying to put a vy Ecotec into my vu Ute and the engine mounts aren’t lining up with the mounting spots in the chassis by around 45mm should I take the mounts off my old engine and put them on or is there any other way around it or is it completely different in general. Thank you
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Is the a/c compressor still on?
If not remove the top a/c idler pulley.
Now you have access to the engine mount bolts, that bolt to the engine.
This is on the passenger side.
Lower engine into place, drop the drivers side first.
Now you can loosely bolt the passenger mount to the kframe. Then lower the motor until the engine mount holes line up with the engine holes. Bolts in & tighten all the bolts up.
Install a/c pulley & a/c compressor.
This should get you there? Its not a hard job.
Immortality
Staff member
Sth Auck, NZ
As above, the mounts are identical so just need a bit of manipulation to get into place.
Kayne_L
19
Ulladulla
Vy
Thanks for the comments bous I got it in eventually I put the drivers side in first then loosend the passenger side engine mount then dropped it into the k frame holes then dropped the engine down. Went in like a glove
Lex
Geelong Victoria
How did you go tightening the mount to the engine after it was installed?
vxcalais_01
VX V6 Calais 3.8 2001
Are the after market whiz bang "lifetime cobra" mounts any better and easier to install ? Seems they have extra pivot point to avoid what the OP had.
Immortality
Staff member
Sth Auck, NZ
You will feel more vibration with those as they are solid rubber, not hydraulic like the factory mount.
They are a very nice mount though, I have a pair here for a new build :)
vxcalais_01
NIce :). Post some pics one you set it up.
