vz 15x7 tyre won't pop on bead
vs_boy94
NSW , Grafton
vs berlina s2
hey I have a set of vz crewman 15x7 stokos and my mate put 205/65/15 tyres on them but they won't pop onto the bead, Iv read some threads on these size rims some say they have run 205/6515 but majority run 225 or bigger, so my question is how could I get them onto the bead or should I just get wider tyres cheers
hakhawk
smooth moderator
Staff member
get someone that knows what theyre doing!!
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Are you putting the air in the right side?
Brisbarnz
Vh sle
I run 205/65/15 on 15x7. I sometimes have prob beading tyres. My fix was removing the inner valve and using my compressor.
Or use a 14" bmx tube between rim n tyre, inflate tube to close up the gap. Then inflate car tyre to bead then deflate tyre n remove tube then inflate tyre again.
I do my own tyres on a changing maching I got from supercheap. Best $100 I spent in a while :).
EYY
VS Statesman
You can use a ratchet tie down around the middle of the tire around its circumference. Tighten it just enough that the lip of the tyre is touching the rim. Then try and pump them up.
I've never had any dramas, haven't needed to use the above method, but apparently works pretty well.
MorganVZ
VZ Berlina
Works very well, just dont go snapping any ratchets near your face.
CONROD
SOMEWHERE in the land of OZ
VZ SS THUNDER 6.0l 6 Sp
Easy as mate. Rub a little dishwashing liquid around the inside bead area of the TYRE, then stand the wheel upright, holding the top of the tyre use your foot and push like buggery on the back face of the rim working the inner bead into position, you might have trouble with the last bit so if you cant get it over the lip don't panic, just leave it and the air pressure will pop it on.
Now turn it round so the front of the wheel is facing you, once again a little dish washing liquid,and apply air pressure to inflate it, you might have to apply a little weight on various parts of the rim to close the gap momentarily to allow it to hold pressure, works each and every time. ( reason why I use dishwashing liquid is its slippery as **** and its easy to wash off after wheel / tyre assembly is done:blah blah:
vc commodore
Like the Leyland Brothers
VC, VH and VY
Your mate doesn't know what he is doing....All 3 sets of 15X7's I have here have 205/65X15 tyres fitted.....I actually suspect he is trying to inflate them with the valve core still in the valve
The way I get them to seat , fit the tyre and stand up right....Remove the valve core....Stand the wheel up, whilst inflating with direct air and hit the centre of the tyre with the elbow. Might need 2 or 3 hits, but it works for me everytime.
