Vz Alloytec timing
Vzalloyissues
24
Vz 2007 alloytec Leo 3.6
I've done the earth on bank 1, about to do bank 2 but when using test light to test for earth through coils it lights up, I connect test to negative and go through each of the 4 pins per coil connector till earth lights up
Fu Manchu
WA.
Just because it lights up doesn’t indicate a good earth. If the earth has high resistance, you’re not going to have a fun time.
Vzalloyissues
24
Can I check for high resistance? Will recheck bank 1 and do all earth's for coils now
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
where would i find your write up fu thanks, im haveing the same problems with miss fire
Vzalloyissues
24
krusing
Melbourne, Bayside
• DTC P0354 – Ignition Coil Cylinder 4 Circuit Malfunction
Cyl 4 is the bank 2, (Passengers Side)
Do you have the OLD Hardware (Coils/Plugs/Injectors) ?
Maybe re-fit each one to start a process of elimination.
Vzalloyissues
24
So I've settled with the fact that maybe my ecu is the issue, as after all this testing and replacement parts cars still **** house, anyone able to tell me if I buy a new ecu pim and bcm, can I just install then all then start my car or will there be other steps that need to be taken, as I've heard you can just plug and play but I'm not sure and don't wanna install everything then have nothing work still
wannaeatyourbrains
52
Mecca
VZ Executive
Man, did you check the wiring? The stuff on that diagram Fu Manchu sent you about ignition supply and ground circuit? You are going to be spewing if you change all your electronics and key and find it was just a cracked or perished wire or bad connector. Which is so likely. It is the little things that get you.
Those computers are robust. You are in Perth. Send it to Kevin Stigant at EFI Auto Parts for testing. That dude is solid. Then you will know if you are barking up the right tree. He might just fix it for you, no programming required.
I can see a bargain spare parts car coming up, All new timing chains and ignition and fuel system components. One door kicked in.
