Vz commodore sv6 5spd auto transmission service
cliffo1986b
nsw
vk commodore 85 carb
Hi all
in need of some help wanting to service my wifes vz sv6 5 speed auto transmission its a 5L40E, i have worked on all other model commodores and i come to service this one and cannot work out how to do it
can some one help please, or have the page out of manual that you can send me
thank you in advance
Gaiter
VZ SS Thunder
Did you just want the fluid change section or after something specific?
Ill upload picture from the manual - Album link = http://imgur.com/a/bruCS
cliffo1986b
nsw
hi gaiter,
just a service change filter and fluid, i just cant see how to fill the transmission up after fluid drain and filter change havn't come across one like this yet.
With what you supplied in images i will give it a go.. if there are anymore pages on 5 speed automatic would be much appreciated (service only) thanks gaiter been a massive help!!!!!!!!!!! one last thing how much fluid does the tranny take too?
Gaiter
VZ SS Thunder
Got those pages too. Here you go:
Fluid Levels
Checking and filling tranny fluid:
ozNick
VL Berlina 3.0 Auto
Some extra notes:
No need to replace the seal in the transmission if it still feels soft.
Keep the plastic spacer from your old filter as your new one may not come with one.
Reuse the metal gasket if the transmission has one.
Use synthetic Dex III or Dex VI to refill.
Depending on the condition of the existing fluid, consider flushing out transmission until clean.
Also consider fitting an external transmission cooler if you are keeping the car.
HTH Nick
shueardm
VZ SV6
@Gatier where are these images from, is it Gregory's ?
I ask because I am looking for my filler hole it's on the other side and it's not a nut or bolt like in the diagram ( 1 )
It's more like the drain plug, I cant remember what they are called. EDIT. From another thread it's a t40 torxbit
99notout
VZ Equip Wagon
Here is the filler plug details and service info including the correct fluid as per year of manufacture.
  • Filler plug.pdf
  • Service.pdf
ozNick
VL Berlina 3.0 Auto
These transmissions (5L40e) are used in a number of BMWs and the consensus in the BMW forums is to use DEX VI.
The service manual, and my Adventra handbook says DEX III. However, DEX VI is DEX III compliant so just go with DEX VI.
If you are going to use DEX III then make sure it is fully synthetic. Those boxes work hard in a Commodore as they are lighter duty than the old 4L60e.
IMHO an additional transmission cooler is more important and a must for the 5L40e if you want keep it.
shueardm
VZ SV6
I appreciate it, where is this from though?
I can not believe that I should be using DEX III in my 2005 SV6 trans, everything I have ever heard even from trans speciailist is it must use DEX VI?
