Caster helps the wheels self centre, I get that and modern cars run a lot more caster but I'm fairly sure my old Commodore (1983 model) has stuff all caster with zero adjustment, stuff all camber correction which only really leaves the toe adjustment?
I was just thinking, he said his measurements were 3 and 4 fat fingers, I would take a fat finger at 10-12mm, the factory setting is +4mm which according to the PDF above equates to about + 0.5##° caster on the LH side. If indeed his fat finger is 10-12mm than we are looking at a difference of about +1° to +1.5° caster.
I know for certain that after fitting new bushes on the family wagon (VX Calais) the difference was about 1/2 a finger.
Part of the reason modern cars run high caster numbers, is due to power steering being a factory fitament....The higher the caster, the harder it is to steer at lower speeds.
Earlier commodores (VB through to VP) had camber and caster adjustment....You turned the strut.....the strut top was offset.....However you couldn't just adjust one, without it effecting the other. Unfortunately not too many people knew this, or could be bothered turning the strut tops, to get a car driving straight, or standing wheels up. Or in laymans terms, stuff the customer, we'll get them reaching for their wallet.
I do know, K-mac supply aftermarket strut tops, which can be used to fine tune either camber or caster. Most lazy buggers will try and flog these off to the unsuspecting person, to "fix" there car, because they can't be bothered helping the customer...The only place these really have is for a race track, where caster and camber adjustment is imperative
The radius rod on the earlier commodores were slightly different, left to right....the left had more of a Z, when compared to the right....This was to give it more caster on the left.
Toe.....This is the adjustment to shorten or lengthen the distance between the front wheels, when looking at the 9 o'clock and 3 o'clock positions....so it can't be used to get a car driving straight, without effecting tyre life.
