vz v6 turbo
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by commodoreuteboy, Sep 4, 2007.
  1. commodoreuteboy
    commodoreuteboy New Member
    Black Vz s 06 Ute
    Does anyone know if theres a sigle or twin turbo kit for the v6 alloytec and how much it costs and if theres anywhere in brisbane who does them.
  2. f1tzy
    f1tzy New Member
    Brissy
    FG XR6T Ute manual
    afaik there is no off the shelf turbo kit for the alloytec. you could get one custom made.
  3. StevieP
    StevieP New Member
    Black VZ SS 6L
    Magic performance do a kit will cost you all up 10K
  4. commodoreuteboy
    Black Vz s 06 Ute
    ok cheers boys thnik ill just go a twin turbo custom job im not to keen on magic performance
  5. impulsesv6
    impulsesv6 Alloytec Garage
    brisbane, QUEENSLAND
    A quick Alloytec
    best of luck with TT, if your gearbaox can handle the extra power
  6. vy-346
    vy-346 New Member
    Sutherland Shire NSW
    FG XR6T 6A & VH-ZXA
    probably will if its an 4L60E.
  7. f1tzy
    f1tzy New Member
    Brissy
    FG XR6T Ute manual
    if its the 6 speed its only rated to 360nm if i remember.
  8. Troy711
    Troy711 Retired Old Fart
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    haha serious? those gearboxes are not worth it as a paper weight!
  9. Silver surfer
    Silver surfer Banned
    04 VY Executive
    what gearboxes do the ls1's run - hint hint
  10. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    4l65e? the stengthened boxes in the awd and ve commodores
  11. impulsesv6
    A quick Alloytec
    here is some info on the 5spd man:
    Hydra-Matic 5L40-E Transmission (M82/MX5)
    Type: five-speed rear-wheel-drive, electronically controlled automatic overdrive transmission with torque converter clutch
    Engine range: 1.8L - 3.6L (M82/MX5)
    Maximum engine torque: 254 lb-ft (344 Nm)
    Maximum gearbox torque: 494 lb-ft (670 Nm)
    Gear ratios:
    First: 3.42
    Second: 2.21
    Third: 1.6
    Fourth: 1
    Fifth: 0.75
    Reverse: 3.02
    Maximum shift speed: 6500 rpm
    Maximum validated gross vehicle weight: 7716 lb (3500 kg)
    4-position quadrant: P, R, N, D & DSC +/-
    7-position quadrant: P, R, N, D, 4, 3, 2
    Case material: die cast aluminum
    Shift pattern: (3) three-way on/off solenoids
    Shift quality: variable bleed solenoid
    Torque converter clutch: pulse width modulated solenoid control
    Available control features: internal mode switch
    reverse lockout
    multiple shift patterns (selectable or adaptive)
    engine torque management on all shifts
    altitude and temperature compensation
    adaptive shift time
    air conditioning cutoff
    Oil Life System
    OBDII/EOBD
    Converter size: 245 mm (reference)
    258-mm dual plate (diameter of torque converter turbine)
    Fluid type: DEXRON III
    Transmission weight: dry: 74.5 kg (175 lb)
    wet: 82.5 kg (186 lb)
    Fluid capacity (approximate): dry: 8.5L (9.5 qt) (with 245mm)
    Pressure taps available: line pressure
    Assembly sites: Strasbourg, France
    what are the 4spd auto and 6spd man box numbers?
  12. impulsesv6
    A quick Alloytec
    the 4spd auto andyman refers to:
    Hydra-Matic 4L60-E/4L65-E Transmission
    (M30/M32/M33/MD6/MK2)
    Type: four speed rear-wheel-drive, electronically controlled, automatic overdrive transmission with torque converter clutch
    Engine range: 2.8L - 5.7L (M30)
    6L (M32)
    Maximum engine torque: 360 lb-ft (488 Nm) (M30)
    400 lb-ft (542 Nm) (M32)
    Maximum gearbox torque: 610 lb-ft (827 Nm) (M30)
    670 lb-ft (910 Nm) (M32)
    Gear ratios:
    First: 3.06
    Second: 1.63
    Third: 1
    Fourth: 0.7
    Reverse: 2.29
    Maximum shift speed (M30): 1-2 6100 rpm
    2-3 6100 rpm
    3-4 6100 rpm
    Maximum shift speed (M32): 1-2 6400 rpm
    2-3 6200 rpm
    3-4 5600 rpm
    Maximum validated gross vehicle weight: up to 8600 lb (3900 kg) (application & axle ratio dependent)
    7-position quadrant: P, R, N, OD, D, 2, 1
    P, R, N, OD, 3, 2, 1
    Shift pattern: (2) two-way on/off solenoids
    Converter size: 245, 258, 280, 300mm (M30) (diameter of torque converter turbine)
    300 mm (M32)
    Transmission weight: wet: 74 kg (163.2 lb) (M30)
    wet: 88.3 kg (194.6 lb) (M32)
    Bottom pan removal: 7.9L (8.4 qt) (245-mm converter)
    10.8L (11.4 qt) (300-mm converter)
    Assembly sites: Toledo, Ohio
    Romulus, Mich.
    Ramos Arizpe, Mexico
  13. vy-346
    vy-346 New Member
    FG XR6T 6A & VH-ZXA
    heh, they might be ****house, but they are strong(er) than the 5spd auto or 6 aisin 6 speed.
  14. minux
    minux Infidel Bear
    I had my 4L60E built to handle 1000hp at the wheels. How is the box not worth it as a paperweight? Stock they are crap, but spend $2000 and you have a box that will handle 500-600hp at the wheels no problem.
  15. vy-346
    vy-346 New Member
    FG XR6T 6A & VH-ZXA
    actually the ls1 was fitted with the 4l60E up until about vy when the hsvs and tonners got the beefed up 4l65E which had the 5 pinion planetarys instead of the 4 pinion in the 4l60e as far as i unsderstand. :) Minux, has your senator sig got the m30 trans or the m32?
  16. commodoreuteboy
    Black Vz s 06 Ute
    will the v8 gearbox fit on..or wats the best gear box that'll fit on with out ne problems..money aint really an issue
  17. impulsesv6
    A quick Alloytec
    why not buy a v8 and spend money on that?
  18. vy-346
    vy-346 New Member
    FG XR6T 6A & VH-ZXA
    somethin different i guess.. commodoreuteboy is ur ute auto or manual? If its auto (4 spd) u should be ok to handle a fair bit, and its easy to have those boxes beefed up anyway :)
  19. burnz
    burnz dah dut dut da dah
    springfield
    2010 CRUZE Diesel
    my box is rated 4L100E (1000 NM) goes perfect.
    as for the original post single turbo is a lot if exhaust pluming,
    twin turbo's are in use will find later
    however check holden website for tt36 torana ---same setup:
    they do have spec sheet.
  20. impulsesv6
    A quick Alloytec
    the torana was different internally then the stock alloytec
