what is this tiny tube for in a V6 VS?
existentialist
VS
Could it be for the air con run off or something?
I ask because I am trying to bleed my system. When i open the value, the bioling coolant shoots out but the level of the coolant container does not fall, as though released coolant is being replaced by air...
Harvs82
41
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
I think you will find that that tube is part of the emissions gear, and should be attached to your charcoal canister, thats the round tube like thing near the radiator.
When you are bleeding the coolant through the valve above the thermostat, when you get a flow of coolant without bubbles or with minimal bubbles, the system can be considered bled, so close up the valve and go for a good long drive, and then check the level so often, as it may need a little topping up here and there.
Immortality
Staff member
Sth Auck, NZ
i also think that it should go to the charcoal cansiter.
Ben6
VE Calais
Can anybody tell me where the other end is supposed to go? Mine came off completely and I worked out that one end was meant to be attached to the charcoal canister, just not sure about the other end...
DannyboyDS
Just hand me the pliers.
39
VS Berlina
well one end actually just goes down into a hole in the lower chassi rail and does nothing on one of them, another should return to the fuel tank I think and the pcv valve from the top of the intake manifold runs back to the throttle body.
thats from a rough and uneducated memory though, my tech book is at my girlfriends.
Andrew426
New Plymouth, New Zealand
VP calais, VR Berlina, VJ valiant, BG5 legacy
The big chunky one that comes up the chassis rail is the fuel tank breather. The two smaller ones go across the top of the engine to the throttle body (i think). Make sure both of these wrap around behind the radiator hose, this keeps them out of the belts.
