cost of fixing/replacing diff?
vpcommo
vr berlina
my diff is starting to get a bit noisy and was just wondering how much it'd be to fix/replace? and also how much would it be to get an lsd put in?
POVRTY
building 5L VB TH 400
41
taree nsw
Wm L98 caprice
i can tell u that i was quoted about $700 to rebuild a diff and put the lsd in, however that was supplying my own lsd center. hope that gives u a bit of an idea
muggo05
HSV VT GTS
my uncle put an lsd centre in his ute for $500 fitted. some place in sydney, will have to ask him where
vpcommo
vr berlina
if its noisy would it just need oil or does it need a rebuild?
delfin82
vs executive s1/ vz berlina
is it noisy when accelerating or it happen when u reach 60kph?
vpcommo
vr berlina
it happens when i reach 60
delfin82
not 100% sure but i think your diff gears the problem unless you take off the cover n have a look at the gear, cause bearing noise do this all the time where as gear noise started when you reach 60 n above.
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
cost me $300 to buy a reconditioned lsd off ebay and $50 for oil, additive, gasket and gasket sealer. installed it myself not really that hard
vs304
VS S1 exec 304 5speed
i went to sa race and sam hooked me up with a fully customised lsd diff new axles, retensioned it to 180ftlbs(standard=85ftlbs)but it was costly at around $1700 but it works so well no effort required.
