Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By WELSHH
Thread: Tech2 OBD II Software
    2002 VY Commodore 3.8 (Dual Fuel)
    Nov 2010
    Perth, WA
    Default Tech2 OBD II Software
    Hi Guys
    I want to active the police mode on my 2002 VY commodore. Plus look up any error codes and have a general nose round the setup of the ECU
    I have the Tech2 OBD II cable for my computer, i have located the ECU socket under the steering wheel
    But not sure what software to download and use to do this? I have had a look at EFILive v4 but couldnt get it going.
    Any ideas would be great as i dont really want to go down and hassle the dealer.
    Thanks
    Adam
    10psi L67 VY S2 Calais
    Jun 2005
    Brisbane Bayside
    V6 needs OBD I (ALDL) not OBD II I thought ?
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    vn hsv wagon
    Apr 2011
    Frankston
    Mate waste of time playing with comp as it dont make it go any faster unless you work engine,do an engine conversion to a supercharged v6
    Jun 2005
    Brisbane Bayside
    It's not about making it go harder, or sounding beast, it's about poking around.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by Fletch_QLD View Post
    Yes you are right mate.
    From vz onwards its protocol is OBD II.
    To the op you need to make the OBD cable it uses OBD II connector but talks OBD I.
    Nov 2010
    Perth, WA
    Hi guys
    Thanks for the reply, im not interested in making the car faster, but enabling the police mode to get a permanent digital speedo, and also looking at any error codes the car has or may get in the future, will also be interesting to have a look at the other settings in there.
    So my Tech2 OBDII cable is no good for the VY 02?
    Thanks
    Adam
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by adamdunford86 View Post
    Hi guys
    That is correct - (no good for VY V6). Also, I don't think police mode is DIY possible, consumer OBD tools can only read info.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Yep, you either need to see Holden and get them to enable police mode, or phreddy from ASR can do it too. My Holden dealer did it for free.
    VZ Thunder - 424RWKW Turbocharged V8 - Parts by AKO Performance
    VY SII HBD Calais L67
    Dec 2006
    Hi guys
    Thanks
    Adam
    The OBDII plug is the same as an OBDI plug (what your car needs), it's just the language/ speed the tech talks to your car in is different.
    Go with the cable and find the correct software to talk 8192BAUD. Send me a pm and I'll link you up
    Quote Originally Posted by 304runner View Post
    Gone are the days of superchargers...
    Do a single turbo correctly and you will see why.
    Mar 2008
    OBD 1 and 2 cables have different circuitry - it's not just a matter of changing software.
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by chargedvx6 View Post
    So OBD II plug can be used if you have the correct software? What about OBD II bluetooth devices?
    2008 VE 6lt SS Ute
    May 2011
    so other then give u a digital speedo, what does police mode actually do?
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by WELSHH View Post
    Xtra 50 rwkw bro But seriously nothing.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    vx s pack II
    Jan 2010
    aLKIDA
    Here is some info mate on the GM 8192 check the link out.
    Can be made up your self just need some electronic and soldering know how.
    GM 8192/160 Baud ALDL Interface
  15. #15
    2008 VE 6lt SS Ute
    May 2011
    Quote Originally Posted by DLFHUB666 View Post
    does it really or u just having me on?
  16. #16
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Only if you have sirens an lights hooked up aswell.
  17. #17
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
  18. #18
    2008 VE 6lt SS Ute
    May 2011
    well that stupid! who ever decided to call it police mode is even dumber then me, it should be called "you got conned into feeling like a cop with your digital speedo mode"
  19. #19
    Mar 2008
    It also disables the stereo volume and radio stations coming up on the speedo screen.
    And the digital speedo comes up by default on the screen regardless of what it was on before you turned the car off.
  20. #20
    VY 3.8L Executive with Clubby Kit. Ex Marked Cop C
    Mar 2011
    Auckland, New Zealand
    It also enables you to "Trap Speed", and recall that trapped speed at a later time.
    You need a Tech2 programming computer. I'm pretty sure a cable and software will only let you read the data. I may be wrong.
  21. #21
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
  22. #22
    2008 VE 6lt SS Ute
    May 2011
    i got "police mode" put on my car yesterday, and apart from the digital speedo etc, im not sure if its just me but my rev limiter seems to be disabled, might just be me but i dunno?
  23. #23
    Mar 2008
    It's just you.
  1. Tech2
    By webwombat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-08-2010, 10:57 AM
  2. Tech2?
    By demo9pro in forum The Pub
    Last Post: 28-08-2009, 08:07 AM
  3. Locked PCM, is Tech2 possible?
    By adamc11 in forum General
    Last Post: 17-06-2008, 01:44 PM
  4. Tech2 Penrith Area
    By Fekason in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-12-2006, 09:28 AM
  5. Access To Tech2 In Adelaide
    By vxexec350 in forum Electrical Wiring / Questions
    Last Post: 04-11-2003, 12:17 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
