This is what my tyre bloke said , so pirelli scorpions it is.
No worries Tim, I have rung Holden and they say that it will be good to fit that size and they also said that if you want they are able to reset the computer and speedo to allow for them larger rolling diameter.
I would like to have a quick look at it before i order the tyres though so if you could get your other half to drop it in for two minutes then that would be good.
Haha nah no showy writing.
Nitrogen is defiantly worth it. The whole point of it is that it keeps the tyre pressures even and does not leak out like normal air, so when you come in for your rotates we will check the pressures then... you don’t need to touch them.
Pirrelli Scorpion STR in 235/55R17 overnight for $425 each fitted ( NZ$)
