Results 1 to 13 of 13
Thread: Vz Alloytec Powertrain Light
    VZ Executive
    Dec 2010
    Cool Vz Alloytec Powertrain Light
    G'Day fellas,
    This is my first post so lets see how it goes. Ive got a 3.6l alloytec with the "Check powertrain light on" , I live in the middle of nowhere and the closest mechanic to me with a diagnostic scan tool is 500 odd km away. Ive replaced both O2 Sensors and Oil Pressure Sensor, "Check powertrain " mil is still there. Any suggestions on what i could try next?. Seems to me like it also has an ever so slight miss only just noticeable and not there all the time,
    Any help you fellas can provide would be great cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If the car has stored a code it will need to be removed by the scan tool. So until you make the big trip for a scan you wont know for sure if that has fixed the issue.
    Oh and welcome to the JC forum.
    and 3 Dangerous non ABS VN's
    VZ Executive
    Dec 2010
    Thanx buddy,
    Cant you reset the ecu on the alloytec by removing battery lead for and hour or so ?
    abg
    abg is offline
    05 VZ v6
    Oct 2009
    You can buy code scanners for ~$100 that connect to a laptop/PC. Would be cheaper than doing a 500km round trip or randomly replacing parts, assuming you get post out where you live?
    And yup you can reset the codes by disconnecting the battery lead.
    "... there's a school of mechanical thought which says I shouldn't be getting into a complex assembly I don't know anything about. I should have training or leave the job to a specialist. That's a self-serving school of mechanical eliteness I'd like to see wiped out." - Robert Prirsig
    VZ Executive
    Dec 2010
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by vtss5.7litre View Post
    Will disconnecting battery remove all stored codes also?
    Not sure - but worth a go
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    No disconnecting battery wont clear stored codes.
    Some codes will self clear if the problem isnt present for a certain number of ignition cycles, but apart from that they need to be cleared with a scan tool.
    Silver Certified.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Could it be a fouled injector?? Plus?? Have u undone anythin? Did u replace the plug on the end of the sensors and sender unit, check the mad is plugged in and perhaps clean the plugs on everything
    Life starts at 200km/h
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    Quote Originally Posted by RiCeY View Post
    you sure? once when i was working on my VZ Senator i forgot to plug in the maf and started the car. engine light came on. wouldn't go away so i took off the heg battery lead for 10 minutes then reconnected started and no engine light.
    abg
    abg is offline
    05 VZ v6
    Oct 2009
    Disconnecting the battery cleared my oxy sensor codes?
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Probably made them not present, they will still be there but not illuminate a warning light.
    Silver Certified.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    1st post hey? Well maybe navigate around the site and get familiar with it. Plus also, before posting a new thread, make sure you use the search function. Its getting so boring and repetitive to read people who are new, posting threads which have been answered 101 times. If you don't believe me on the number of threads about this already, then click my link below. I answered another thread already with many many many posts on this topic.
    So, note to yourself "search first" post second;
    Powertrain warning light
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by HoldenOnn View Post
    In the tiime you took to write such a lengthy reply on how much he is in the wrong about posting instead of searching, you could of gone an got counselling about your issues... Leave the bloke alone, if noone posted and everyone searched then what fun would there be on Just Commodores...
LinkBacks (?)
  1. 06-12-2011, 11:37 PM
  2. 27-10-2011, 08:37 PM
  3. 28-08-2011, 02:48 AM
  4. 04-06-2011, 03:45 PM
  5. 03-05-2011, 01:07 PM
  6. 04-03-2011, 12:38 PM
  7. 18-02-2011, 09:06 AM
  8. 29-01-2011, 08:16 AM
  9. 13-01-2011, 11:02 AM
  10. 05-01-2011, 12:55 PM
  11. 01-01-2011, 07:52 PM
  12. 27-12-2010, 09:20 AM
  13. 22-12-2010, 10:17 AM
  1. Powertrain warning light
    By VT2VEight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2012, 05:20 PM
  2. Powertrain warning light
    By Leonie in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-10-2010, 10:38 PM
  3. CHECK POWERTRAIN light comes up on dash. UH OH
    By v8s&2wheels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2010, 10:08 PM
  4. Intermittent Powertrain Light on Gen3 V8
    By Demons1964 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2006, 06:09 PM
  5. VT SS, Powertrain warning light.
    By dissident in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2005, 03:01 PM
Tags for this Thread
