Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: HELP!!! Alloytec oil filter cap wont come off!!!! Also clutch starting to die!!
    Vz ute missing 2 cylinders :(
    Apr 2008
    perth/oakford
    Angry HELP!!! Alloytec oil filter cap wont come off!!!! Also clutch starting to die!!
    Hey guys as title says i cant get my oil filter cap of my vz ute 175kw (i think).
    I did a full service on it when i bought it :
    Flushed the engine with additives then flushed it again with cheap oil then put some good oil in(forgot what i put in), flushed gearbox twice with cheap engine oil then put good stuff in and flushed diff once with diff oil and filled it up again, so i finished all that and was happy that all the hard stuff was done and only had one last easy thing to do, change the oil filter. No matter how hard i try i cant get it of even with 2 people fully pull on it!! i just dont want to do what that other bloke did and brake the bolt of lol.
    The car has done 87 000 km (did the service at 85k) and im wondering if the oil filter has ever been changed? Does anyone know how i can get this of without breaking it? Or take it to a mechanic and see if they can do it?
    I also think my clutch is starting to die. The previos owner was a female, and apparently only used it to put horse gear in the back and only towed the horses with a horse float a couple of times. But i had my doubts. Took a video the other night to get a better look at what its doing. Click here to view gay alloytec vid lol
    Looks like the clutch is struggling to grip when i change to 3rd gear or is this normal?? i wasnt giving it full juice and its a manual not auto.
    Thanks in advance
    Simon.
    Supercharged VU SS
    Feb 2006
    The Shire
    just use more leverage. get a big pipe and put it over a breaker bar and it should come off. also try it when its cold so the metal has not it expanded. if that doesnt work warm up the motor and see if that works...
    all else fails use a rattle gun
    to answer your clutch question. standard ones are ****, everyone is in the same boat as you.
    Apr 2008
    perth/oakford
    Quote Originally Posted by naf33n View Post
    thanks for the reply.
    yeh i been told to try that just gotta fine some piping lol
    yeh figured that with the clutch.
    dunno whether to change it or get a v8, if it can last a couple of months before i sell it, ill be happy.
    2007 SVZ Wagon
    Aug 2007
    Hill River, SA
    Make sure that you have thr correct size socket (23mm I think from memory) and it unscrews in an anti-clockwise direction. From what you've indicated someone may have put Loctite on the threads.
    Apr 2008
    perth/oakford
    Quote Originally Posted by Benboy View Post
    thnx 4 reply. so u recommend just keep trying till it comes loose or i break something?
    Deltak is offline Donating Member
    VZ Executive
    Apr 2007
    Just a thought, but if you warm the engine, fit the correct socket and use a breaker (solid) bar to the socket.
    Apply the torque to the bolt and hit (tap) the top of the socket (light to medium) with a hammer. The impact generally shocks the siezed connection and the twisting should loosen the threads.
    It shoud not take too much force.
    Aggro_VE's Avatar
    Aggro_VE is offline The Overseer
    A lazy VE
    May 2005
    Lake Macquarie
    Exactly! the oil filter cap shouldnt be on that tight period! if that's the case. They do have a torque setting when tightening it up, BUT i didn't have a torque wrench that went that low for the setting, so I marked a tiny mark on the cap and the housing so when I put it back on it matches up to the marks.
    Seriously, I'm trying to see things from your point of view but I can't get my head that far up my arse!!
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    sounds stupid but see if you can tightern it up more...?
    At our work on the planes, if we cant get screws/bolts out, we tighten them up a little bit more, then untighten them. Works everytime. Put a FARK load of inward pressure on it aswell.
    VZ SSZ- LS1
    Apr 2008
    perth/oakford
    ah k thanks for all the suggestions and tip ill try them as soon as i can find the the correct socket! Someone must have moved it somewhere >< looks like ill be heading down to supercheap to get another
    thanks again.
    VZ Acclaim
    Oct 2009
    Hey guys, I'm having the exact same problem. Can't get my bloody filter off...
    Is it Anti-Clockwise to get it off? I've tried both ways, and it won't budge.
  1. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-08-2014, 10:00 AM
  2. Starting issues after new fuel filter and injectors installed!! HELP!!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 05:17 PM
  3. VN starting problems, kicks over but wont run
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 03:39 PM
  4. V6 alloytec oil filter
    By LaoK in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-08-2005, 11:06 AM
  5. vz alloytec 175kw air filter upgrade
    By ry79 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-07-2005, 05:25 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
