Julie
moderator- for now anyway
- Mar 27, 2004
- 1,671
- 110
- 63
- Location
- Western Sydney, NSW
- Blown VT Calais 355 + SC VY V6
First thing you need to do is remove the dash fascia to get to the instrument cluster. To remove the dash fascia, unclip the gear shifter and power window surround (just gently pull it upwards being careful not to break anything). Now undo the 2 screws on either side of the cigarette lighter (or dummy).
Now you need to undo the 2 screws at the top of the instrument panel. Now lift down the panel undernath the steering wheel (the thing u open to get to fuses),then undo the 3 screws at the top holding the fascia in.
The dash fascia will now be ready to partially remove, carefully unclip the fascia. Before the fascia is completely removed you will have to unplug all the electrical connectors (lights switch, hazards, fog lights, trip mode), to do this simply reach from behind and pull them out whilst holding the front. Depending on what stereo you have and how it has been mounted, this may also need to be removed. Now the dash fascia can be carefully removed.
Its best to now lower the steering wheel as far down as it will go. The instrument cluster has 2 screws holding it in at the top. Unscrew these, now pull out the cluster just far enough to get your hand behind it and unplug it from the wiring harness. Now the cluster can be carefully pulled out.
Thats the hardest bit out of the way, to change the bulbs is a 5 sec task, simply twist out the dodgy bulb and twist in a new one.
Now you gotta put it all back together, which is just a simple case of revresing the removal procedure.
It really is easier than it sounds, I have done it numerous times and never had any problems. It won't take too long either. If you have any more questions about this, let me know and I'll try to help u out.
