04 vz sv6 had to be hotwired to start then after it started check powertrain has come on and not left what could be going on?
Lisa's04vzsv6
30
2004 vz sv6
Hey all I hope someone can help,
I went to go to work today but my car had nothing not even a click but my dash lights worked, then I called my partner and he had to hot wire my car to get it started then after it started I had a check powertrain light come on but had to drive to work cause I was about to be late, I've now finished work and one back to go home but my car started okay but the powertrain code is still there as well as a service Engine oil before it does the system check wtf could be going I dont want to **** my car by driving it if it's something serious I'm hoping it's just a dirty throttle body or something
Fu Manchu
WA.
It’s not a dirty throttle body.
The only way you will get a starting point to investigate is either replace every part in the car one by one or plug a diagnostic scan tool of half decent quality in and see what codes have been generated. They don’t tell us what is broken. They tell us where to start looking.
lout
60
Langwarrin Victoria
did he remove whatever he "hotwired"
without knowing what he did its a bit difficult to diagnose this
original fault could have been many things
BlackVXGTS
Melbourne, SE
By "hot wire", do you mean that he used jumper leads from his car to your car, to start your car?
