SirSheen
- Nov 27, 2021
- 2
- 0
- 1
- Age
- 24
- Location
- Queensland
- Vz sv6
Any help, suggestions are much appreciated. Sorry for a long post I just want to explain the whole story so who ever reads can have the best idea of what this could be. had my car sitting in the parents yard for a little bit now as it keeps overheating, a while back I blew the gearbox(auto) and something to do with that started the whole overheating problem (engine temp hot came up I pulled off the road 10 seconds later as I was in traffic and just as I turned it off I had steam goin everywhere and she was pouring at the reservoir). I took it to the mechanic to fix it and that he did, until it started overheating again. Mechanic put in a new radiator, radiator cap, serviced gearbox, flushed the hell out of the system because the blown gearbox pushed oil into the coolant I believe he refilled my power steering also. After driving around a bit one power steering hose clamp was loose and nearly killed the pump tho I was able to fill it up, tighten it, save it. Also put the car on hoist and all the bolts holding the gearbox oil pan on weren’t as tight as they could be an gearbox oil was all around it and that was very concerning, I tightened them and I tried to top it up(this could be an issue of overheating as I know it stuffs up pressure if it isn’t the right amount).
shortly after this is when it started overheating again so a few weeks after I had taken it to the mechanic, I had bought another car so that’s why I’ve been able to leave the car alone. So the car runs fine and the temperature just slowly keeps on rising til it gets to the red but I haven’t been letting it get that high, don’t want to. Any ideas ???
Next I will be changing thermostat and/or gearbox service to make sure it’s at the right amount of oil.
