Crisis63
- Jun 18, 2011
- 155
- 1
- 0
- Location
- Adelaide
- Monaro CV8R, Landcruiser 100 Series 4.7L
Job details
Make: Holden
Carline: VE Commodore 3.6 4 Speed Auto
Service: 135,000km/9 Yr Serv
Est Time: 2 Hour(s)
Est Cost: $334.00 - 441.00 (Inc. GST)
Average Cost: $413.98 (Inc. GST) *This is the actual cost based on over 152 service invoices
Job instructions
Carry out service to manufacturer specifications.
Replace engine oil and filter.
Check all drive belts, condition and length.
Check cooling system.
Replace air cleaner element.
Check exhaust system.
Check all oil levels.
Check steering & suspension components.
Check front and rear brakes for wear.
Check all seat belt components.
Check park brake operation (adjust if required).
Check lights, wipers, tyre pressure & all fluid levels.
Replace remote battery(s).
Clean and lubricate auto trans shift linkage.
Check all air conditioning components and performance.
Check battery electrolyte and fluid level.
Carry out road test to manufacturer handbook.
Replace brake & clutch fluid every 2 years regardless of km's.
Replace coolant fluid every 5 years regardless of km's.
Reset service reminder display.
Check transmitter range of security system.
Check for & complete all relevant campaigns & recalls.
Rotate & balance wheels if required.
Inspect constant velocity joints for damage.
Check final drive & auto trans for leaks.
Inspect tyres for irregular wear or damage.
Inspect oil pan shield for damaged or loose parts.
Check final drive oil level.
Check park brake linings & drums for wear.
Parts
Battery cen - 1 piece(s)
Element a/cl - 1 piece(s)
Oil filter pkg - 1 piece(s)
Oil & Lubricants
Standard Engine Oil - 6.5 Litre(s)
Armed with this information basically you are changing the oil, filters and a small battery.
$40 for oil, $5 oil filter, $20(?) air filter, $5 (?) battery = > $80.
Most of those checks are easily accomplished with a reasonable amount of automotive knowledge. I rekon some of them probably get “bypassed” anyway even in dealership services….
Make: Holden
Est Time: 2 Hour(s)
Job instructions
Parts
Oil & Lubricants
