STEEV888
- Aug 11, 2010
- 307
- 3
- 0
- Age
- 33
- Location
- central coast
- '95 200sx.
First off, hello and welcome in this thread i will (obviously) post everything i have done/will do to my car, ill try to explain it in detail in a sort of diy way as everything will be done by myself, if you have any questions or suggestions or even "wtf did you do that for" please comment away as all opinions are valued. also if you have one of these also and are having trouble post it here i may be able to help.
Bad punctuation and grammar is bad.
Purchased: October 2011
Price: not going to say but i definitely believe i got a good deal, it was under 10k (but owes me so much more now (shakes fist)
Km's: 250k when i got it 265k now. with full receipts of everything ever done to it since birth and 5000k service increments.
Mods when i got it: FMIC, Eboost, bosch 044, hks bov, pod, hd clutch, upgraded front brakes, pineapple bushes, 3inch straight through exhaust to a unmeasured size massive cannon, 18 inch wheels though bald rubber, ssl springs in front and sl springs in rear, adjustable rear upper arms. did not know at time of purchase but 27mm front sway bar and 20mm rear sway bar.
It also has twin immobilisers, yes twin.. it had 1 then the most previous owner decided he wanted another one, can't be too careful living in sydney I guess lol
Mods i have done to it:
1st get rid of the stupid bov, it was cool for about 1 week.
2nd was coilovers, a genuine necessity for a car of this kind in my opinion i went with k-sport kontrol pro dampers, they are pretty good and are rock hard on firm and comfortable(er) on soft i took it to forster for a weekend hunting trip and there was 30 minutes of bumpy dirt track, set it all to 0 and cruised on through like it was nothing.
3rd is just your basic 2.5" dose pipe, nothing special. sounds nice.
4th was 2 HID kits, 6000k. I chose this as they are the whitest/brightest ones, installation was very straight forward as everything just connects to your loom, with this car though, I did need to remove the headlights to get the bulbs in.
5th.. I'm getting to it.... see below.
'Future' mods: shimmed 4.3 diff to re, gearbox rebuild, all new bearings and synchros, extreme xhd cushion button clutch, wheel bearings, castor arms, tie rod ends, solid subframe mounts, solid diff bushes, rocker stoppers, rocker cover gasket, rear main seal, flywheel, upgraded shift springs, needle roller spigot bush, steering lock spacers, front and rear strut braces and painting the brake calipers purple. i will also be welding a 3 inch by 8 inch flexi pipe into the exhaust to protect against those random scrapes.
(by future mods i mean this is all getting done in the next 2 weeks, so i though id better get to it making a build thread.)
future future mods: better sound system, good single din unit with kick arse front splits and most likely a single 12 in the boot and some crappy sick by nines to fill in the space in the back. and either another hot dog muffler or a varex cat back.
far future mods: gt2871r or gtx3071 high mount set up with external gate screamer, power fc computer, injectors, thermo fans, new harmonic balancer, r33 brakes all round with QUALITY pads and other stuff that i will think of at the time but is not of grave importance now, any suggestions ?
if after the motor mods i blow the engine, im rebuilding it fully forged and spraying the car purple. or doing a vh45de conversion. but this is years away.
Problems ive had: well the original rear shocks were non existent but i solved that pretty quick with the coilovers.
shortly after buying it the exhaust manifold gasket went which was really annoying to do, the first time i had ever worked on a turbo car and it took me an entire day just to get it out. upon repairing i found the turbo gasket was broken also so i replaced that.
about 2 months later the exhaust gasket went again and i was furious (mainly at myself for not nipping up the bolts again) and procrastinated about replacing it for about 3 weeks until i got super sick of the noise and awkward head turns. the 2nd time i did it i had it out, replaced and in within 3 hours and i was pretty impressed with that.
then the front main seal started leaking, which was a pretty easy fix, more annoying than anything. if you want to know how just ask.
next i had a sticky caliper which ate through one of my brake pads, it was as simple as removing them, linishing the piston and lubricating it with pbr rubber grease, i also replaced the rear pads with just some basic bendix pads
the rocker cover gasket started weaping oil about a month ago but thats getting replaced when i do the big maintenance in a couple weeks.
pretty soon after getting the car i noticed a flat spot at about 3krpm on high boost but knew nothing about turbos and didnt know what to make of it, a friend came for a ride a few months later and said its not normal go get it checked, so i took it to my local mod shop to put it on the dyno and what do you know the high boost was causing detonation and the car actually made less power on 13 psi than it did on 8psi which is stock tune.
finally 2nd and 3rd grinds if your doing high rpm changes.
power: 150rwkw and the motor is pretty stock atm. when i brought it it came with a dyno sheet of 200rwkw and i was instantly skeptical of this.
Cosmetically its stock besides the wheels, the rear wing was removed by the previous owner but i want to put it back on eventually (he patched up some holes). it has no body kit or anything and thats the way i like it. the only after market attachment i am thinking about getting is a small roof lip to go over the rear window as i think these look nice.
cant think of much else to say, i have seriously taken one pic of the car and a couple of the mods since i purchased it as im not really into that but ill get some soon and post away (*sigh* looks like ill have to give it a washy washy)
pics soon
pics soon
pics soon
Hope you like it.
Most recent info put up 12/06/2012.
pics soon
pics soon
pics soon
Hope you like it.
