2 bar map sensor
plymouth_hemi_69
tearoha nz
vs v6 turbo, vn v8 turbo
hey im looking at getting this New Buick supercharged V6 map sensor (2 bar) for sale - TradeMe.co.nz - New Zealand for my vs commodore my question to him was .hey mate im currently upping the boost on my supercharger. Would this fit my Eco tech engine? and he replies Only if your running an aftermarket computer that requires an external 0-5v signal from a map sensor. Thanks
im afraid i dont understand can someone help me out can i swap my standard map sensor with this 1? and also i understand it will need a retune
plymouth_hemi_69
tearoha nz
also wondering
does anyone know will the standard l67 injectors be fine for me to boost 10 -12 psi (
they are 36lb injectors)
also who knows about bearings for a new pully getting 1 made up but need some pix or explained as to what people mean buy saying make sure you get bearings with your new pully
cheeers
Pub247
Melbourne S.E.
Ford Fairmont
if you got a vs it doesnt run map sensor so essentially you wont need one unless you decide to convert to earlier model ecu or aftermarket ecu (most of which have inbuilt map sensors anyway
plymouth_hemi_69
tearoha nz
so
you are saying i can just put in injectors and get a tune?
Pub247
Melbourne S.E.
Ford Fairmont
yes pretty much yours runs a maf sensor instead of map sensor
plymouth_hemi_69
tearoha nz
ok
thanks heaps for your help any idea on the other questions at all?
vnrockit
vn calais & vt acclaim
yes you should be able to use that map sensor but you will need to wire it into your ecu
and have a mafless tune done make sure there is a tuner that can do mafless tunes with kalmarker around you first
i also tapped a mat sensor into the lim before i got tune done
super6 injectors are good for a bit over 300hp
plymouth_hemi_69
tearoha nz
thanks
for that but i think i will stay without one now cheers but any other info would be great on the tuning side of things
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yip VS wont have a MAP sensor has a maf instead you van roll back to VR auto ecu to get MAP sensor capabuility and auto control are you auto or manual.or you can get a kalmaker workshop tune to replace the MAF sensor with a MAP sensor.
VN S1
You can get a reprogrammed ecu that reads both together i was reading about it today although its really a lot of money wasted in your case as a map sensor isnt needed.
