2002 vx l67 running rough under load and all dash lights on
Brockamac
Mount Gambier south Australia
2002 vx l67 commodore
Runs fine on idle and revs fine in neutral, just seems to surge and lack power under load and all dash lights are on, I've only just bought the vehicle
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Probably plugs or leads for the surging. All dash lights on, alternator probably over charging, check voltage at the battery terminals with the engine running. Voltage should be around 14 - 14.4 volts, anything much higher or lower is no good, replace voltage regulator. Overcharging for too long could cause damage.
When you say all dash lights on, do you mean all or just certain ones?
