westerlybreeze
- Sep 22, 2009
- 357
- 5
- 18
- Location
- "No fixed address" Auckland, NZ
- VS Calais Supercharged "Auuusiecouch"
It's also not NA (Naturally Aspirated) :banstick:
Gtp 85 has cracked the 200kw no longer a street car, and there aren't many at all that are NA with those numbers.
Certainly achievable but by no means easy.
pfft v8s proven fact from factory arent as quick as v6 t5 vn v6 127fwkw they did a 15sec qtr mile vn v8 165kw yeah the 8s have a good note and torque but not worth the money to do a conversion just for the "power" my mate had a "freak" motor in his vr basically stock motor use to stand still no breaks 1 st through to 2nd on an auto now he has built the motor 40thou on block big head work massive cam and evreything else u could think of machining cost $4000 alone but its gunna do a 13flat with decent drivelineMy ecotec used to make 171.8 rwkw standard bottom end. It's now in pieces and I am changing a few parts around. I'm hoping for 190rwkw and a high 13 second pass. If you want to build a v6 go for it.
Forget an the bashers telling you to buy a v8. So what if you do buy a v8 do they think you will have the fastest car in the world?
If you are going to enjoy your v6 then build it and have fun with it, and then when you race a v8 you can wave as you go past them. It won't be easy but nothing with cars is, good luck
