wetherow
- Jul 24, 2023
- 14
- 9
- 3
- Age
- 36
- Location
- adelaide
- VE series II sv6 SIDI 2011
Hi guys,
Just after some advice as im kinda stumped.
I have a SV6 VE commodore sedan series II which has an LLT engine in it. about 6 months ago it developed a bad misfire on bank 2 affecting all B2 cylinders - turned out to be a blocked/damaged cat which I have had brand new high-flow cats installed which fixed the issue. During this time i have had the timing chains done with heavy duty chains/new tensioners and guides as well as new spark plugs and ignition coils.
After having the new cats installed - the car now has this issue of slow cranking only when its warmed up or after being driven for a while (approx and hour of hwy driving) like its got a flat battery and essentially wont start. I have replaced the battery, alternator, and starter motor as well as checked the earth points and the wiring loom for resistance and voltage with a multimeter which have all been well within parameters. but it still has the slow crank when warm issue. I have also checked the fuse relays and they're all solid.
I have hooked it up to an ECU reader and it is showing codes for cat system below threshold on B1 and 2 which i presume is due to the high flow cats but it also have codes for running too rich fuel/air mix P0172 and P0175. I have checked the O2 sensors while connected to the scanner and the voltages are within normal ranges on live scanner data as well as long term.
Any ideas?
Any ideas?
