RevNev
- Dec 9, 2020
- 2,587
- 3,507
- 113
- Location
- Adelaide
- VF II SSV Redline Ute
Master cylinder size has been discussed several times with Holden fitting 27mm master cylinders with Brembo brakes. My Aug '17 SSVR Ute has a 25mm master cylinder I believe is absolutely a factory fitment perhaps incorrect fitment or maybe not. The question whether or not a 4-piston brake upgrade needs the bigger 27mm master cylinder, here's a photo of an MY15 R8 Maloo Ute 25mm factory master cylinder fitment with the HSV 4 piston AP brakes. I'm not sure if the GTS 6-piston calipers had the 27mm master cylinder but the HSV 4 pistons certainly don't.
